DEC31
Muscle powered electronic dice
If you are tired of shaking dices in your hands in order to randomize them before throw, you can shake some electronics instead. The realisation of this device is very interesting. It doesn't have any batteries, it is realised using ATtiny13 microcontroller and it is capable of generating enough power to power the micro and LEDs.
Power generation is accomplished by using Faraday power generator. It is basically a wire wound on a tube with neodymium magnets moving in that tube. In order to generate a dice's number (roll a dice), you must shake the device to generate some power. On the authors website you can find a double-dice version of the device.
© Gadre
[ Source: Gadre ]
- Electronic thermostat (23-02-2004) [@Schematics/Everything else]
- Coating electronics in clear polyester resin (13-11-2009) [@News]
- Battery powered telephone bug (07-03-2004) [@Schematics/Bugs]
- Small electronic siren v2 (10-08-2007) [@Schematics/Audio devices]
- Dice value readout using Arduino AVR (22-09-2009) [@News]
- Small electronic siren (10-10-2006) [@Schematics/Audio devices]
- Electronic whistle (23-02-2004) [@Schematics/Audio devices]
- Electronic combination lock with AT89c2051 (04-04-2004) [@Schematics/Microcontrollers]
- Electronic stethoscope (23-02-2004) [@Schematics/Audio devices]
- 1.5V battery powered motor (14-02-2004) [@Schematics/Everything else]
