/Projekti/GSM call alarm
pica
picb
Broj download-a: 28,880
Ocjena: (2.94, glasova 6349)
Datum: 20-02-2005
501_gsm_call_alarm_c.rar
Bookmark and Share Komentari (109)
komentar [69]
Upisuje se umjesto tog broja. Prije nego sto kliknes "BURN" ili "Program" dugme na IC-Prog-u, iskljuci onu kvaku "CP" i onda ce moci da verifikuje.
komentar [68]
Ja imam jedan problem sa programiranjem PIC-a. Kada ucitam HEX fajl i izvrsim verifikaciju dobijem odgovor da je problem u adresi verify fail at adres 0000h! i to mi se dogadja sa *,hex fajlom sa sms alarmom i sa gsm alarmom. Koristim allPic i ic-prog 105c.. I jos jedno pitanje da li se broj upisuje umesto broja +38762xxx ili u nastavku probao sam i jedno i drugo i ništa. Hvala
komentar [67]
Nokia phones running on this circuit hex Publish
komentar [66]
Connect it to a sensor you are planing on using. "It has 1 sensor input and another input - state (stanje). If state input is = 0V than the device is "active" and it monitors the sensor input. The device is deactivated when state pin is connected to Vcc (+). Sensor input is triggered by 0V."
komentar [65]
sensor and on / off How to input to be connected.
komentar [64]
I don't know if it will work with A60 or A70, you must try it!
komentar [63]
senzor i za uključivanje / isključivanje Kako će veze. hvala.
komentar [62]
Thank you very much, it just stars work after adding the resistor of 4k7.The project is very useful. Thanks a lot.
komentar [61]
Actually, download the circuit from here http://www.elektronika.ba/666/tiny-gsm-alarm-system/ and see how GSM is connected to PIC (see the resistors and their values).
komentar [60]
If the phone keeps loosing network coverage, try putting a resistor of 4k7 on GSM RX line!
