/Projekti/GSM call alarm
pica
picb
Broj download-a: 28,880
Ocjena: (2.94, glasova 6372)
Datum: 20-02-2005
501_gsm_call_alarm_c.rar
Bookmark and Share Komentari (109)
Siemens C45 SHOULD work great! Steal it from your aunt :) And C25 should NOT work though.
ok i will try and on ebay.. hehe thanx... siemens are hard to find in my hometown than sony erc.. but knew lately that my girlfriend has a C25, and my Aunt has a C45. are they compatible also? hope so... hehehe THANK YOU VERY MUCH trax! You're a blessing...
Well, what I would really advise you to do is to get an old Siemens S25 or C35/M35 from eBay, or you can try that 4,91* crystal and get back with results :)
trax, may i ask again? There is no 5Mhz Crystal Oscillator available in my hometown.. i've search every electronic shops and no luck. they have only 4, 4.5, 4.9152, 8 , 10, and 16 Mhz Crystal Oscillators. Is it ok if I use 4.9152 Mhz with the Sony Ericsson phone? what can you advise? Thanx trax...
Ok I'll Try....Thanx trax... I very much appreciate ur help... Thank You Very Much...
You should be able to use any model with internal modem such as Ericsson T28 for example. I really can't say, you must try it yourself!
may i ask, if what particular Sony ericsson phone is compatible with this project... I badly needed ur help.. thank you very much....
What about Sony Ercsson (K750i)? Did someone already tray with Sony Ericsson? Can i expect positive result? Thank you in advance!
If you want to use Ericsson phone instead of Siemens, you must use 5 MHz crystal instead of 10 MHz !
Stranica komentara: <...91011
