/Projects/GSM call alarm
pica
picb
Download counter: 28,880
Rating: (2.94, votes 6347)
Date: 20-02-2005
501_gsm_call_alarm_c.rar
Bookmark and Share Comments (109)
comment [29]
Check the connection with the phone. You probably didn't connect something right. This alarm module works fine, many people built it. You will need to try a bit harder!
comment [28]
I build circuit again and it is working.The yellow diode is blinking every 15 s.I found siemens S45 but when i connect the phone to the circuit, nothing happen, yellow diode still blinking. What is the problem now??????????????? Thanks again.
comment [27]
Sorry it is 16 pin OSC1
comment [26]
If i connect the Pic on simple pic programmer it is say is ok, It was working for 3 days.What is problem Thanks??????????
comment [25]
Hi, is PIC16f84A 20/p DEAD.The circuit not respond, when i connect the power, nothing happen, but if a touch the pin where is connect the oscillator i think is 12 pin all diodes are flashing, and it doesn't work. Thanks??????????????????Please
comment [24]
You can try with WinPic it works 100\%.I've tried it and i assure you that works.You could find it on google and it's free. You should adjust com port, and that is
comment [23]
Hi i build the alarm but it was working for 3 days not in my car but, i connected to PC on 12 V, i wanted to test it. after 3 days the yellow light not blinking, i think is dead, why ????? now if i touch the 11 pin on PIC with finger the yellow light is flashing constantly. I wonder what is the problem?The PIC or crystal, HOW to check the PIC, because it is expensive here ? Thanks a lot bye.
comment [22]
hi trax...how are ya? ive tried your simple pic 16f84 programmer, i build it and tried it in icprog but it shows verify code error when i program it. can i ask if what hardware setting will i use? or there is something to configure? i used JDM in the settings but it displays error in the end. Thanx Trax
comment [21]
Every car alarm has one wire that is GND when alarm is armed, and it is VCC when alarm is not armed. You will find that wire in your car-alarm and connect it with GSM Call Alarm "ENABLE" input.
comment [20]
Hi me again ,i build the all circuit,but i still wait for pic,i cant find it in shops.That is ok.But i have a question? If i put all sensors to 4 door if i close the door on car how to activate the alarm, i mean to touch on/off wire to GND out of my car,funny a?I mean how to put it in standby position,if i do that before open the door, when i open the door it will ringing.I mean can i activate with ringing to mobile which is connected to GSM car alarm.I found with sms but with ringing? Thank you, and good
Comment page: <...91011>
