/Projects/GSM call alarm
pica
picb
Download counter: 28,880
Rating: (2.94, votes 6347)
Date: 20-02-2005
501_gsm_call_alarm_c.rar
Bookmark and Share Comments (109)
comment [69]
Upisuje se umjesto tog broja. Prije nego sto kliknes "BURN" ili "Program" dugme na IC-Prog-u, iskljuci onu kvaku "CP" i onda ce moci da verifikuje.
comment [68]
Ja imam jedan problem sa programiranjem PIC-a. Kada ucitam HEX fajl i izvrsim verifikaciju dobijem odgovor da je problem u adresi verify fail at adres 0000h! i to mi se dogadja sa *,hex fajlom sa sms alarmom i sa gsm alarmom. Koristim allPic i ic-prog 105c.. I jos jedno pitanje da li se broj upisuje umesto broja +38762xxx ili u nastavku probao sam i jedno i drugo i ništa. Hvala
comment [67]
Nokia phones running on this circuit hex Publish
comment [66]
Connect it to a sensor you are planing on using. "It has 1 sensor input and another input - state (stanje). If state input is = 0V than the device is "active" and it monitors the sensor input. The device is deactivated when state pin is connected to Vcc (+). Sensor input is triggered by 0V."
comment [65]
sensor and on / off How to input to be connected.
comment [64]
I don't know if it will work with A60 or A70, you must try it!
comment [63]
senzor i za uključivanje / isključivanje Kako će veze. hvala.
comment [62]
Thank you very much, it just stars work after adding the resistor of 4k7.The project is very useful. Thanks a lot.
comment [61]
Actually, download the circuit from here http://www.elektronika.ba/666/tiny-gsm-alarm-system/ and see how GSM is connected to PIC (see the resistors and their values).
comment [60]
If the phone keeps loosing network coverage, try putting a resistor of 4k7 on GSM RX line!
Comment page: <12345678...>
