comment [88]
- From trax on 21-06-2010 at 08:03:54
Ne treba nikakav interface! Spaja se direktno kablovima.
Download counter: 28,880
Rating: (2.94, votes 6347)
Date: 20-02-2005
PLEASE POST OR EMAIL SCHEMATIC
THANKS
Da li je potreban neki interfeis između GSM i proekta vidim da se spominje MAX 232 ako treba
da li može shema. Hvala
A60 work great. Thank you very much.
IP: 90.191.242.183
I used 19200 bps and standard AT commands for Siemens GSM phones (look for it on Google).
Hi! I want to know the baude rate you used with this divice. It's possible for you to send me
the protocole you used (AT command...)?. I try it with siemens A65, it's ok. thanks.
ma na ES-u ima lik koji se potpisuje tr4ck pa reko da nisi to ti... Ali nema veze posto sam ja
dosadan i pitam sve redom za pomoc...
Nisam, daj mi taj link do foruma da vidim o cemu se radi.
Toliko muke oko ATZ :) salim se hvala ti do neba i samo jos jedno pitanje da nisi na drugom
forumu gde ti se u nicku pojavljuje 4???
