/Projekti/GSM SMS alarm
smsalarm
Broj download-a: 30,134
Ocjena: (2.98, glasova 5807)
Datum: 17-12-2004
500_sms_alarm.rar
Bookmark and Share Komentari (102)
komentar [22]
Trax imam stari Ericsson T10s da li bi radilo kada bih stavio 5Mhz krisal.Ako bi da li može 5,0688Mhz trenutno to mogu naći. Zahvaljujem.
komentar [21]
No it can't. You should make "GSM controller v2 (TwoWay Thing)" if you have DLR3-P Nokia laying around.
komentar [20]
can it work with nokia phones or any other phones (incase i connect the same pins rx,tx,gnd with the same pins)
komentar [19]
Hi, Thanks For Reply I am trying that circuit, everything is ok Upto Red LED Glow, but with sms uploader I can't Connected. Please Provide Me pin config. For PC To PIC. I Am Using PIC16F84A 04/P When I click SMS Uploader "Connect" Buttan Green LED Blink One Time. But A Massege apeared In German Language. Please Give Me Your mail ID. Or Send me Note For That Fault On My mail ID: kr_ishan@hotmail.com
komentar [18]
Hi, I used it, but it can give you problems since -04 version is for 4MHz crystals. In this circuit 10MHz is used, so you really should get the -10 version.
komentar [17]
can i used pic 16F84A 04/P instead of pic 16f84A 10/P
komentar [16]
Well, do you see any LEDs blinking?? Does anything work at all?
komentar [15]
until now i could not connect the board to the pc, so the sms uploader did not work
komentar [14]
Well, what seems to be the problem? Is your PIC working properly? Did you connect the phone properly? ...?
komentar [13]
hi all, until now i could not manage to make this device work. and you promised me to send me a sample.
Stranica komentara: <...91011>
