/Projekti/GSM SMS alarm
smsalarm
Broj download-a: 30,148
Ocjena: (2.98, glasova 5875)
Datum: 17-12-2004
500_sms_alarm.rar
Bookmark and Share Komentari (102)
You have HEX file to burn into the PIC first. After that you connect ALARM to PC and work with uploader. The uploader will import text of SMS messages that you with PDUspy program. You must use EEPROM (24C512/515 - see circuit diagram for eeprom info), it cannot be replaced with MAX232!!!
Dear Trax, Thanks for your nice effort , because i finally found what i am looking for,i jurst need to ask you 2 questions : 1- after connecting thins great crcuit , i just connect the device to the PC and press the programming button then the sms uploader will do the rest, i mean there is so ASM files to be burn in the PIC 2- if i don't have the 24LC515 can i use the MAX232 with the same connections
Stranica komentara: <...91011
