/Projekti/GSM SMS alarm
smsalarm
Broj download-a: 30,134
Ocjena: (2.98, glasova 5810)
Datum: 17-12-2004
500_sms_alarm.rar
Bookmark and Share Komentari (102)
komentar [12]
PDUspy: http://www.nobbi.com/pduspy.html
komentar [11]
gde je program pduspy. da li je neko konacno napravio ovaj uredjaj da mu radi i da li moze da se modifikuje da upravlja na udaljenoj lokaciji recimo da resetuje nesto
IP: 195.252.75.45
hi i would love to have a copy of the asm file if possible and mod it for my reqirements. Can you please send to danbicks@yahoo.co.uk. Big thanks
IP: 86.112.188.232
ppozz svima može li mi neko reći koji mobitel da spojim na ovo i kako da spojim ovo na računar za programiranje
yes trax i did what you said, i will revise the steps again with you. 1- the programming button is relased 2- with the power on, (red led is blinking is it is still and the green led is constant.) 3- pluged the serial port in the PC 4- Push the programming button . then connect to the device using the smsuploader. when i press same some time no message appear and some other time the message that i told you appears. so advice me what can i do ? i will sent you a vedio to your mail about the steps
The message you get "Greska pri slanju..." means that the SMS uploader software didn't receive a confirmation byte from SMS Alarm. Did you put SMS Alarm into the programming mode as described in the document?? I think you didn't...
Dear Trax, thanks for your help, i did all your instructions and it i think it is working i red led is not blinking and the green one is blinking twice then take a while then reblink again but when i use the sms uploader it connected to the device but i does not save any data it propemt a message saying "--------------------------- SMS Uploader --------------------------- Greška pri slanju! Nisam dobio potvrdu poslanog podatka od ureðaja! --------------------------- OK ---------------------
i burned the pic with the hex file that i was downloaded, and the crystal is 10 Mhz so what so u think???
You probably didn't burn the HEX file into your PIC micro controller. Maybe your crystal is not working properly so PIC doesn't have a valid clock source? Triple check everything!
hi Tax, This this me again, finally i got the 24LC515 and followed your steps as u told me, but i don't know why it is not working, i connected a 5 V DC as input but non of the leds lights up , can u help me please?
Stranica komentara: <...91011>
