- From mramorcanin on 28-12-2009 at 19:05:46
gde je program pduspy. da li je neko konacno napravio ovaj uredjaj da mu radi i da li moze da
se modifikuje da upravlja na udaljenoj lokaciji recimo da resetuje nesto
IP: 195.252.75.45
Download counter: 30,137
Rating: (2.98, votes 5831)
Date: 17-12-2004
IP: 195.252.75.45
hi i would love to have a copy of the asm file if possible and mod it for my reqirements. Can
you please send to danbicks@yahoo.co.uk.
Big thanks
IP: 86.112.188.232
ppozz svima može li mi neko reći koji mobitel da spojim na ovo i kako da spojim ovo na
računar za programiranje
yes trax i did what you said,
i will revise the steps again with you.
1- the programming button is relased
2- with the power on, (red led is blinking is it is still and the green led is constant.)
3- pluged the serial port in the PC
4- Push the programming button .
then connect to the device using the smsuploader. when i press same some time no message appear
and some other time the message that i told you appears. so advice me what can i do ?
i will sent you a vedio to your mail about the steps
The message you get "Greska pri slanju..." means that the SMS uploader software
didn't receive a confirmation byte from SMS Alarm. Did you put SMS Alarm into the programming
mode as described in the document?? I think you didn't...
Dear Trax,
thanks for your help, i did all your instructions and it i think it is working
i red led is not blinking and the green one is blinking twice then take a while then reblink
again but when i use the sms uploader it connected to the device but i does not save any data
it propemt a message saying "---------------------------
SMS Uploader
Greška pri slanju! Nisam dobio potvrdu poslanog podatka od ureðaja!
OK
i burned the pic with the hex file that i was downloaded, and the crystal is 10 Mhz
so what so u think???
You probably didn't burn the HEX file into your PIC micro controller. Maybe your crystal is not
working properly so PIC doesn't have a valid clock source? Triple check everything!
hi Tax,
This this me again, finally i got the 24LC515 and followed your steps as u told me, but i don't
know why it is not working, i connected a 5 V DC as input but non of the leds lights up , can u
help me please?
