/Schematics/Bugs/FM bug 420-480 MHz
How about getting that old Nokia phone out of your drawer and turning it into something freakishly cool? I will not lie to you, you will need a few tools and skills such as soldering/desoldering and making PCBs.
You can download files (schematics) by clicking on red download button below.
buba5
The range of this FM bug is around 1km with full CR2032 battery and good conditions. As the battery discharges the transmission range reduces as well as the oscillation frequency (VCO).
buba7
buba1
This bug can be received at frequency of around 430 MHz. Use NFM demodulation in reception. Yes, you can use your PC TV tuner card to receive audio from this transmitter!
All parts on this bug are from 2 Nokia phones:
R0464 VCO - from - Nokia 3210
All other parts - from - Nokia 1611
You can receive this bug using these receivers that you can also build:
- http://hem.passagen.se/communication/uv916rec.html
- http://hem.passagen.se/communication/supertuner.html
- http://hem.passagen.se/communication/sprec.html
Download counter: 15,410
Rating: (2.92, votes 4855)
Date: 05-03-2008
Lokalna verzija ove stranice: FM bubica 420-480 MHz
408_fmbubica420-480mhz.zip
Bookmark and Share Comments (28)
imam problem sa skidanjem sheme ako neko ima i moze da mi poshalje. merci.. IP: 212.200.207.52
IP: 212.200.207.52
dobra stvar IP: 193.198.140.188
IP: 193.198.140.188
dali je neko pravio takve prijemnike sa PC TV karticama? Molim, da se javi na mail ili da stavi projekat na site. Unapred puno hvala! IP: 62.108.118.7
IP: 62.108.118.7
dali nekoj znae kade mozam da najdam sema za link predavate i priemnik ako nekoj znae neka mi pise na msn: foxy_mkd@hotmail.com IP: 92.53.47.102
IP: 92.53.47.102
Nisam testirao bateriju niti domet u zgradi. Buba je poprilicno jaka pa ce se cuti bilo gdje u zgradi, garant. Jos nesto, na shemi je potrebno zamjeniti mjesta onim dviju zavojnicama. Pogresno sam im naznacio vrijednosti - naopako :)
Bravo trax, fenomenalno. Ali neznam kdje da naðem takav prijemnik, i daj mi još kaži koliko dugo drži ova baterija i koliko je realan domet u neki zgradi. Pozdrav. Iggy IP: 86.58.28.70
IP: 86.58.28.70
vrlo domisljato konstruktivno resenje. cestitam.
extra bubica i frekfencija gde se slisa IP: 77.46.174.206
IP: 77.46.174.206
Comment page: <123
