- From black angel on 26-04-2009 at 15:48:38
Kakve ste vi kamere koristili ?
Ja bih izradio nesto ovakvo ali nemam ideje odakle kameru izvaditi ili nabaviti.
Small video transmitter, simple to build. Coil is 4 windings on 5mm drill diameter and wire is 0.5mm in diameter. Transmitter works in VHF band (5-12ch).
Author (sent by): M-key
Download counter: 3,970
Rating: (2.88, votes 2414)
Date: 31-03-2007
Lokalna verzija ove stranice: Jednostavni video predajnik
Tags: predajnik, transmitter, video. +add your tag
umesto ovog tranzistora staviti drugi 2n2222 ili 2n2219
IP: 109.92.205.62
nista od ove seme, ja bi pravio ,ali da je domet bar 100m
IP: 89.146.157.218
IP: 89.146.157.218
Aj doradite semu da moze i audio!
IP: 212.200.25.14
IP: 212.200.25.14
radi dobro, jedino je domet oko 5 do 10m
IP: 60.208.64.177
IP: 60.208.64.177
Stavi izmedju plusa i minusa 10nF kondenzator,zatim antenski kondenzator treba da bude 4.7pF a
ne 47pf i umesto trimera od 220oma stavi trimer od 470oma.Paralelno tirajnom krugu stavi
otpornik od 1Kohm.to ce smanjiti Q faktor zavojnice i povecati sirinu k
ja pravio ovo i neradi kako treba.
uhvati se na 5m i to prelosa slika i mala sirina kanala
IP: 89.146.140.28
IP: 89.146.140.28
