Altium Designer
Drago_Zg
Altium Designer
Post by Drago_Zg »
1. Download
2. Create Account
3. Request License
Download your fully-functional copy of Altium Designer so you can explore the benefits of taking a holistic approach to electronics design over the next 30 days.
First, click the "download" button below and save the zip file to your computer.
As the file downloads, complete the final two steps on this page to complete your request for an evaluation license.
After installing Altium Designer using the downloaded file, enter your new evaluation license code when prompted…and start exploring!
skineš lijepo sa :
http://d3iwdtfoi3eh2.cloudfront.net" onclick="window.open(this.href);return false;
Verzija je 9.0.0.17654.zip
Ovdje ima sve i nije bez veze Altium Designer najrašireniji i smatraju ga najboljim programom u PCB.
Re: Altium Designer
Ovaj link ne radi...
Re: Altium Designer
Bome ne radi. Dragec, ako si ti nekaj zbrljal - popravljaj.
Možda sad održavaju stranicu, u kom slučaju se moramo strpiti i opet pokušati. :roll:
MladaNada
Re: Altium Designer
Post by MladaNada »
INSTALLATION:
1. Install running autorun.exe file in AltiumDesignerWinter09 folder
2. Copy both Altium.alf and dxp.exe files from AltiumDesignerWinter09CRACK folder to DRIVE:\Program Files\Altium Designer Winter 09
3. You can now enjoy in this great program!
SIZE:
Packed.........1.45 GB
Unpacked.....1.48 GB
rapidshare(dot)com/files/202350284/Altium_Designer_Winter_09_Bulid_8.0.0.15895.part01.rar
rapidshare(dot)com/files/202373234/Altium_Designer_Winter_09_Bulid_8.0.0.15895.part02.rar
rapidshare(dot)com/files/202399427/Altium_Designer_Winter_09_Bulid_8.0.0.15895.part03.rar
rapidshare(dot)com/files/202425440/Altium_Designer_Winter_09_Bulid_8.0.0.15895.part04.rar
rapidshare(dot)com/files/202913035/Altium_Designer_Winter_09_Bulid_8.0.0.15895.part05.rar
rapidshare(dot)com/files/203241163/Altium_Designer_Winter_09_Bulid_8.0.0.15895.part06.rar
rapidshare(dot)com/files/203262396/Altium_Designer_Winter_09_Bulid_8.0.0.15895.part07.rar
rapidshare(dot)com/files/203282298/Altium_Designer_Winter_09_Bulid_8.0.0.15895.part08.rar
rapidshare(dot)com/files/203302842/Altium_Designer_Winter_09_Bulid_8.0.0.15895.part09.rar
rapidshare(dot)com/files/203324720/Altium_Designer_Winter_09_Bulid_8.0.0.15895.part10.rar
rapidshare(dot)com/files/203346971/Altium_Designer_Winter_09_Bulid_8.0.0.15895.part11.rar
rapidshare(dot)com/files/203370222/Altium_Designer_Winter_09_Bulid_8.0.0.15895.part12.rar
rapidshare(dot)com/files/203391406/Altium_Designer_Winter_09_Bulid_8.0.0.15895.part13.rar
rapidshare(dot)com/files/203411442/Altium_Designer_Winter_09_Bulid_8.0.0.15895.part14.rar
rapidshare(dot)com/files/203427434/Altium_Designer_Winter_09_Bulid_8.0.0.15895.part15.rar
PASSWORD:
Technophreak@ForumW.org
Eto vam pa javite valja li sta da skinem...ali 1.5Gb ne moze da ne valja!
Drago_Zg
Re: Altium Designer
Post by Drago_Zg »
Sve je moguće! Samo sam ja s tog linka skinuo.
Možemo i drugim putem:
http://www.altium.com" onclick="window.open(this.href);return false; ili https://trial.altium.com/#eval" onclick="window.open(this.href);return false;
Zaista ima biblioteka oko 2Gb.
Vrijedno downloadati svakako i nije piraterija.
Što bi održavali, pa nisu to zagrebačke ulice, krpa na zakrpi!
Hvala na upozorenju!
Pozdrav!
Drago_Zg
Re: Altium Designer
Post by Drago_Zg »
Hvala Mlada Nada, ja zaista zabrljao, nenamjerno.
MladaNada
Re: Altium Designer
Post by MladaNada »
Skinuo sam i instalirao program!
Za mene prekomplikovano i preobimno, bukvalno CAD za elektroniku, ima sve sto vam moze pasti na pamet!
crash override
Re: Altium Designer
Post by crash override »
hey jel' mi mozes poslati samo ova dva fajla,tj linka od njih na PM...skinuo sam s drugog sajta cd,i ima neki patch ali ne radi,a imam kaspersky pa mi firewall sve blokira... ;)
mixa
Re: Altium Designer
Post by mixa »
Da li je neko mozda vec kreirao Microchipov PIC 16f88? Ako jeste, da li moze da mi posalje tu biblioteku.
Hvala
Re: Altium Designer
Zar je bitno koji je pic?
Nadji neki sa istim rasporedom pinova i pakovanjem koje ti odgovara. Ja tako radim.
mixa
Re: Altium Designer
Post by mixa »
Pa od ovih koje imam u microchipovoj biblioteci, nema nijedan sa istim rasporedom. A nesto bas i nisam vjest editovanju. Treba mi samo da sklopim projekat. Ako imate Vi vec spakovan, mozete li mi poslati.
Re: Altium Designer
Radim u eaglu. Tako da nece ici...
Drago_Zg
Re: Altium Designer
Post by Drago_Zg »
" mixa " što je napisao, prosto nije točno. Ako ima Microchipovu biblioteku, a ima je, onda ona apsolutno
sadrži i legendarni, neuništivi PIC 16F84, sa svojoim pripadajućim footprintom.
Traženi PIC 16F88 ima identičan raspored nožica, kao dobar, stari PIC 16F84.
Razlika je samo u dodatnim funkcijama, tako da na pinu 4. pored MLCR može se konfigurirati
RA5. Ako se koristi interni oscilator, tada pin 15. možemo preimenovati u RA6, a analogno time
i pin 16. može postati RA7. Da ne bude zabune, to radimo u inicijaciji programa, a time
obuhvaćena je i konfiguracijska riječ. Ako pak imao namjeru da radimo sa externim ili vanjskim oscilatorom ili rezonatorom ili RC konstantom, nemamo potrebu bilo što da mijenjamo, jer je preslika PIC 16F84.
Mislim da sam bio dovoljno jasan.
Hvala na objašnjenju!
mixa
Re: Altium Designer
Post by mixa »
Hvala na objasnjenju.
Ovako treba da izgleda taj PIC:
http://img687.imageshack.us/img687/9190/16f88.jpg" onclick="window.open(this.href);return false;
Da li neko zna, zasto mi opcija edit nije aktivna, kada selektujem komponentu u listi biblioteke i idem na desni klik, jer kao sto vidite, moracu da editujem.
Drago_Zg
Re: Altium Designer
Post by Drago_Zg »
Dobro pitanje. Odmah se uočava da se počinje raditi s Altium designerom. I to je jako dobro.
Krenimo redom:
Altium Designer poznaje više vrsta biblioteka, s kojima se izvršavaju pojedini projekt.
Tako imamo između ostalog:
- Integrated Libraries (*.INTLIB)
- Installable Libraries (*.SCHLIB , *.PCBLIB)
Naredba EDIT se ne upotrebljava za promjeu pojedinih elemenata bilo u shematicu ili footprintu.
Iz jednog evidentnog razloga jedinstava shematika i PCB, što čine jenu cijelinu.
Osim toga Integrated Libraries (Integrirana biblioteka) se ne može nikako mijenjati, već ostaje uvijek ista.
Postoji samo promjena mjesta pojedinih pinova u shematiku ( kad želimo grupirati pojedine pinove i slično). I to se može zaključati da se ne može više slučajno promijeniti (Lock).
Installable Libraries (Instalirana Biblioteka) se može editirati i to samo u Shematic Librariu.
Integriranu biblioteku da bi promjenili, unatoč njezinoj kompaknoj zatvorenosti, moramo pozvati:
- Opšen a document - zatim
- Library - zatim
- Miscellaneous Devices -zatim
- Extract Sources
Kad smo otvorili extract Libraria sada moramo zadati:
- Close Project
- Kod toga pitat će nas "Save Changes to Miscellaneous Devices. LIBPKG ?
Naravno odgovor je: YES.
Preostaje nam samo da pospremimo sa SAVE u folder.
Otvaranjem SCH Library možemo:
-promijeniti shematsku sliku elementa sa svim nazivima pinova i rasporeda pinova, oblika tijela shematika kao i footprinta koji njenu pripadaju.
-Tako možemo pridružiti nekoliko različitih footprintova (DIP ili SMD)
Ako se poštuje filozofija rada Altium Designera onda je rad u ovom programu konforan i lak,
a ako se nešto nezna stoji na raspolaganju velika dokumentacija u pdf u samom programu, što si vjerovatno i pogledao ili na službenim stranicama Altiuma i video prezentacija.
Drago_Zg
Re: Altium Designer
Post by Drago_Zg »
Ispravak:
Opšen a document _treba zamjeniti sa:
Open a document
pavle1993
Re: Altium Designer
Post by pavle1993 »
Imam altium designer 6 i interesuje me dal u njemu postoje biblioteke sa tda integrisanim kolima... Ja sam probao da trazim medjutim ne mogu da nadjem jer ima more biblioteka... Inace do sada nisam radio ni u jednom ovakvom programu pa bi bio jako zahvalan ako bi mi neko objasnio kako da ubacim ili nadjem tda IC...HVala unapred!
Drago_Zg
Re: Altium Designer
Post by Drago_Zg »
Svakako ima ! Koji TDA te interesira ?
pavle1993
Re: Altium Designer
Post by pavle1993 »
TDA 7054 i TDA 2003...
pavle1993
Re: Altium Designer
Post by pavle1993 »
pardon, ne TDA 7054 nego 7057 :)
