MAX7219 I 8X8 LED DISPLAY
febo26
Re: MAX7219 I 8X8 LED DISPLAY
Post by febo26 »
Pedja da li si mislio na ovo: na ovaj nacin mogu kontrolirati pojedinu diodu na displeju ( to je upis za jedan max7219 chip)
prikaz displeja:
ako napisem da je Y=1 i X=%00000001 onda mi svijetli dolje desno prva dioda
87654321
00000000 ----255
00000000
00000000
00000000
00000000
00000000
00000000
00000001 -----1
ako napisem da je Y=1 i X=%11111111 onda mi svijetli cijeli prvi desni red
87654321
00000001 ----255
00000001
00000001
00000001
00000001
00000001
00000001
00000001 -----1
ako napisem da je Y=2 i X=%11111111 onda mi svijetli ova kombinacija
87654321
00000010 ----255
00000010
00000010
00000010
00000010
00000010
00000010
00000010 -----1
primjer koda s kojim to radim
'*  Name    : UNTITLED.BAS                                      *
'*  Author  : ZELJKO FERIC                                      *
'*  Notice  : Copyright (c) 2014 [select VIEW...EDITOR OPTIONS] *
'*          : All Rights Reserved                               *
'*  Date    : 13.10.2014                                        *
'*  Version : 1.0                                               *
'*  Notes   :                                                   *
'PIC16F877A
 Define	OSC	4		' Set Xtal Frequency
   TRISA = %00111111    'port a je cijeli ulazni
TRISB = %00000000
TRISC = %00000000
TRISD = %00000000
TRISE = %1111
ADCON1 = 7	   ' PORTA i PORTE su digitalni  ISKLJUCI KOMPARATORE I ANALOGNE ULAZE
include "modedefs.bas"
'-----VARIABLES-----
ADDRESS var word 'variable address for display
DATAREG var word 'variable data register for display
Y VAR BYTE  'okomice
X var BYTE  'sadrzaj okomice
'----- symbolos ------
SYMBOL CLK = PORTB.0
SYMBOL DAT = PORTB.1
SYMBOL LOAD = PORTB.2
'-----PIN SETUPS-----
low dat 'data pin for MAX7219 (1)
low clk 'clock pin for MAX7219 (13)
low load 'load pin for MAX7219 (12)
'-----MAX7219 SETUP-----
ADDRESS = $0C : DATAREG = $01 : gosub MaxWrite ' NO SHUT, NORMAL OPERATION
ADDRESS = $09 : DATAREG = $00 : gosub MaxWrite ' COMBINACION BINARIA, NO DECODE
ADDRESS = $0A : DATAREG = $09 : gosub MaxWrite ' INTENSIDAD DE LEDS 1(MIN) A F(MAX)
ADDRESS = $0B : DATAREG = $07 : gosub MaxWrite ' SCAN LIMIT NUMERO DE DIGITOS
ADDRESS = $0F : DATAREG = $00 : gosub MaxWrite
GOSUB brisi_display
main:
y=1
X=%11111111
ADDRESS = y
DATAREG = x
GOSUB MAXWRITE
PAUSE 2000
gosub brisi_display
pause 500
goto main
MaxWrite:
shiftout DAT,CLK,MSBFIRST,[ADDRESS,DATAREG] 'Shift out the data to the 'MAX7219 'first the address, then data.
pulsout LOAD,1 'load the data into the MAX7219
return
brisi_display:
for Y = 1 to 8 'write $0F (blank) to all digits
ADDRESS = Y : DATAREG = $00
gosub MaxWrite
next Y
return
Tako nesto...
Displej var byte[8]
displej[0]=%10101010
displej[1]=%01010101
displej[2]=%10101010
displej[3]=%01010101
displej[4]=%10101010
displej[5]=%01010101
MAIN:
GOSUB brisi_display
PAUSE 1000
GOSUB Prikazi_Niz
PAUSE 1000
GOTO MAIN
Prikazi_Niz:
for Y = 0 to 7 'write $0F (blank) to all digits
ADDRESS = Y+1 : DATAREG = Displej[i]
gosub MaxWrite
next Y
return
Probaj ovaj kod, ako na displeju dobijes sahovsku tablu, onda dalje lako mozemo... Prvo napraviti shiftovanje, pa dodavanje novih karaktera...
febo26
Post by febo26 »
nece iskompajlirati pokaze gresku u ovom redu
Bad array expression
da li fali neka FOR petlja u tvom kodu
Moram ici bebaca zeni pomoc okupati,vracam se za pola sata za komp
Nisam pisao ceo kod. Nego sam samo napisao sta bi trebao ubaciti u onaj sto si vec testirao...
Ajd probaj sad sa ovim...
    TRISB = %00000000
    TRISC = %00000000
    TRISD = %00000000
    TRISE = %1111
    Y VAR BYTE  'okomice
    GOSUB brisi_display
Displej var byte[8]
    main:
 GOSUB brisi_display
PAUSE 1000
GOSUB Prikazi_Niz
PAUSE 1000
    goto main
Prikazi_Niz:
gosub MaxWrite
next Y
return
    MaxWrite:
    return
    brisi_display:
    gosub MaxWrite
    next Y
    return
febo26
Post by febo26 »
'*  Date    : 20.10.2014                                        *
'*  Version : 1.0                                               *
'*  Notes   :                                                   *
	 #CONFIG
__config _HS_OSC & _WDT_ON & _PWRTE_ON &_CP_ON  & _BODEN_OFF & _LVP_OFF
#ENDCONFIG
    Define	OSC	20		' Set Xtal Frequency
        TRISB = %00000000
        TRISC = %00000000
        TRISD = %00000000
        TRISE = %1111
        Y VAR BYTE  'okomice
        ADDRESS = $0A : DATAREG = $00 : gosub MaxWrite ' INTENSIDAD DE LEDS 1(MIN) A F(MAX)
        GOSUB brisi_display
    Displej var byte[8]
    displej[6]=%10101010
    displej[7]=%01010101
        main:
     GOSUB brisi_display
    PAUSE 1000
    GOSUB Prikazi_Niz
    PAUSE 1000
        goto main
    Prikazi_Niz:
    for Y =0 to 7
    ADDRESS = Y+1
    DATAREG = displej[y]
    gosub MaxWrite
    next Y
    return
        MaxWrite:
        return
        brisi_display:
        gosub MaxWrite
        next Y
        return
da bi dobio sahovnicu morao sam nadopisati dva reda u ovoj tabeli
Displej var byte[8]
i "pokazi niz"prepravljen je u ovaj oblik i sada imam sahovnicu koja se pali i gasi u ritmu jedne sekunde
kako je u main-u duga pauza tako brzo on blica
Prikazi_Niz:
for Y =0 to 7
ADDRESS = Y+1
gosub MaxWrite
next Y
return
To je ok sad...
Sledece probaj napraviti ono siftovanje sto sam vec negde pisao.
PomeriNiz:
For i=0 to 6
Displej[i]=displej[i+1]
next i
Displej[7]=0'Ovo bi trebao biti novi red koji ce da izadje sa desne strane, ali dok ne proradi siftovanje neka ga 0.
Dodaj ovo gore u prethodni kod, i izmeni main u ovo
        main:
         GOSUB PomeriNiz
         GOSUB Prikazi_Niz
         PAUSE 1000
        goto main
Sada bi se trebala slika pomeriti svake sekunde za 1 red ulevo.
febo26
Post by febo26 »
radi. slika se pomjera s desne strane na lijevo
E sad treba upariti onaj include sa ovim programom i to je to :ohno:
Na kraj onog koda dodaj ovo:
SendChar:
    SELECT CASE Char
    Case 32
    	FC(0)=$00:FC(1)=$00:FC(2)=$00:FC(3)=$00:FC(4)=$00 ' // sp
    Case 33
    	FC(0)=$00:FC(1)=$00:FC(2)=$2f:FC(3)=$00:FC(4)=$00 ' // !
    Case 34
    	FC(0)=$00:FC(1)=$07:FC(2)=$00:FC(3)=$07:FC(4)=$00 ' // " (shown as \ in Lookdown table)
    Case 35
    	FC(0)=$14:FC(1)=$7f:FC(2)=$14:FC(3)=$7f:FC(4)=$14 ' // #
    Case 36
    	FC(0)=$24:FC(1)=$2a:FC(2)=$7f:FC(3)=$2a:FC(4)=$12 ' // $
    Case 37
    	FC(0)=$c4:FC(1)=$c8:FC(2)=$10:FC(3)=$26:FC(4)=$46 ' // %
    Case 38
    	FC(0)=$36:FC(1)=$49:FC(2)=$55:FC(3)=$22:FC(4)=$50 ' // &
    Case 39
    	FC(0)=$00:FC(1)=$05:FC(2)=$03:FC(3)=$00:FC(4)=$00 ' // '
    Case 40
    	FC(0)=$00:FC(1)=$1c:FC(2)=$22:FC(3)=$41:FC(4)=$00 ' // (
    Case 41
    	FC(0)=$00:FC(1)=$41:FC(2)=$22:FC(3)=$1c:FC(4)=$00 ' // )
    Case 42
    	FC(0)=$14:FC(1)=$08:FC(2)=$3E:FC(3)=$08:FC(4)=$14 ' // *
    Case 43
    	FC(0)=$08:FC(1)=$08:FC(2)=$3E:FC(3)=$08:FC(4)=$08 ' // +
    Case 44
    	FC(0)=$00:FC(1)=$00:FC(2)=$50:FC(3)=$30:FC(4)=$00 ' // ,
    Case 45
    	FC(0)=$10:FC(1)=$10:FC(2)=$10:FC(3)=$10:FC(4)=$10 ' // -
    Case 46
    	FC(0)=$00:FC(1)=$60:FC(2)=$60:FC(3)=$00:FC(4)=$00 ' // .
    Case 47
    	FC(0)=$20:FC(1)=$10:FC(2)=$08:FC(3)=$04:FC(4)=$02 ' // /
    Case 48
    	FC(0)=$3E:FC(1)=$51:FC(2)=$49:FC(3)=$45:FC(4)=$3E ' // 0
    Case 49
    	FC(0)=$00:FC(1)=$42:FC(2)=$7F:FC(3)=$40:FC(4)=$00 ' // 1
    Case 50
    	FC(0)=$42:FC(1)=$61:FC(2)=$51:FC(3)=$49:FC(4)=$46 ' // 2
    Case 51
    	FC(0)=$21:FC(1)=$41:FC(2)=$45:FC(3)=$4B:FC(4)=$31 ' // 3
    Case 52
    	FC(0)=$18:FC(1)=$14:FC(2)=$12:FC(3)=$7F:FC(4)=$10 ' // 4
    Case 53
    	FC(0)=$27:FC(1)=$45:FC(2)=$45:FC(3)=$45:FC(4)=$39 ' // 5
    Case 54
    	FC(0)=$3C:FC(1)=$4A:FC(2)=$49:FC(3)=$49:FC(4)=$30 ' // 6
    Case 55
    	FC(0)=$01:FC(1)=$71:FC(2)=$09:FC(3)=$05:FC(4)=$03 ' // 7
    Case 56
    	FC(0)=$36:FC(1)=$49:FC(2)=$49:FC(3)=$49:FC(4)=$36 ' // 8
    Case 57
    	FC(0)=$06:FC(1)=$49:FC(2)=$49:FC(3)=$29:FC(4)=$1E ' // 9
    Case 58
    	FC(0)=$00:FC(1)=$36:FC(2)=$36:FC(3)=$00:FC(4)=$00 ' // :
    Case 59
    	FC(0)=$00:FC(1)=$56:FC(2)=$36:FC(3)=$00:FC(4)=$00 ' // ";"
    Case 60
    	FC(0)=$08:FC(1)=$14:FC(2)=$22:FC(3)=$41:FC(4)=$00 ' // <
    Case 61
    	FC(0)=$14:FC(1)=$14:FC(2)=$14:FC(3)=$14:FC(4)=$14 ' // =
    Case 62
    	FC(0)=$00:FC(1)=$41:FC(2)=$22:FC(3)=$14:FC(4)=$08 ' // >
    Case 63
    	FC(0)=$02:FC(1)=$01:FC(2)=$51:FC(3)=$09:FC(4)=$06 ' // ?
    Case 64
    	FC(0)=$32:FC(1)=$49:FC(2)=$59:FC(3)=$51:FC(4)=$3E ' // @
    Case 65
    	FC(0)=$7E:FC(1)=$11:FC(2)=$11:FC(3)=$11:FC(4)=$7E ' // A
    Case 66
    	FC(0)=$7F:FC(1)=$49:FC(2)=$49:FC(3)=$49:FC(4)=$36 ' // B
    Case 67
    	FC(0)=$3E:FC(1)=$41:FC(2)=$41:FC(3)=$41:FC(4)=$22 ' // C
    Case 68
    	FC(0)=$7F:FC(1)=$41:FC(2)=$41:FC(3)=$22:FC(4)=$1C ' // D
    Case 69
    	FC(0)=$7F:FC(1)=$49:FC(2)=$49:FC(3)=$49:FC(4)=$41 ' // E
    Case 70
    	FC(0)=$7F:FC(1)=$09:FC(2)=$09:FC(3)=$09:FC(4)=$01 ' // F
    Case 71
    	FC(0)=$3E:FC(1)=$41:FC(2)=$49:FC(3)=$49:FC(4)=$7A ' // G
    Case 72
    	FC(0)=$7F:FC(1)=$08:FC(2)=$08:FC(3)=$08:FC(4)=$7F ' // H
    Case 73
    	FC(0)=$00:FC(1)=$41:FC(2)=$7F:FC(3)=$41:FC(4)=$00 ' // I
    Case 74
    	FC(0)=$20:FC(1)=$40:FC(2)=$41:FC(3)=$3F:FC(4)=$01 ' // J
    Case 75
    	FC(0)=$7F:FC(1)=$08:FC(2)=$14:FC(3)=$22:FC(4)=$41 ' // K
    Case 76
    	FC(0)=$7F:FC(1)=$40:FC(2)=$40:FC(3)=$40:FC(4)=$40 ' // L
    Case 77
    	FC(0)=$7F:FC(1)=$02:FC(2)=$0C:FC(3)=$02:FC(4)=$7F ' // M
    Case 78
    	FC(0)=$7F:FC(1)=$04:FC(2)=$08:FC(3)=$10:FC(4)=$7F ' // N
    Case 79
    	FC(0)=$3E:FC(1)=$41:FC(2)=$41:FC(3)=$41:FC(4)=$3E ' // O
    Case 80
    	FC(0)=$7F:FC(1)=$09:FC(2)=$09:FC(3)=$09:FC(4)=$06 ' // P
    Case 81
    	FC(0)=$3E:FC(1)=$41:FC(2)=$51:FC(3)=$21:FC(4)=$5E ' // Q
    Case 82
    	FC(0)=$7F:FC(1)=$09:FC(2)=$19:FC(3)=$29:FC(4)=$46 ' // R
    Case 83
    	FC(0)=$46:FC(1)=$49:FC(2)=$49:FC(3)=$49:FC(4)=$31 ' // S
    Case 84
    	FC(0)=$01:FC(1)=$01:FC(2)=$7F:FC(3)=$01:FC(4)=$01 ' // T
    Case 85
    	FC(0)=$3F:FC(1)=$40:FC(2)=$40:FC(3)=$40:FC(4)=$3F ' // U
    Case 86
    	FC(0)=$1F:FC(1)=$20:FC(2)=$40:FC(3)=$20:FC(4)=$1F ' // V
    Case 87
    	FC(0)=$3F:FC(1)=$40:FC(2)=$38:FC(3)=$40:FC(4)=$3F ' // W
    Case 88
    	FC(0)=$63:FC(1)=$14:FC(2)=$08:FC(3)=$14:FC(4)=$63 ' // X
    Case 89
    	FC(0)=$07:FC(1)=$08:FC(2)=$70:FC(3)=$08:FC(4)=$07 ' // Y
    Case 90
    	FC(0)=$61:FC(1)=$51:FC(2)=$49:FC(3)=$45:FC(4)=$43 ' // Z
    Case 91
    	FC(0)=$00:FC(1)=$7F:FC(2)=$41:FC(3)=$41:FC(4)=$00 ' // [
    Case 92
        FC(0)=$02:FC(1)=$04:FC(2)=$08:FC(3)=$10:FC(4)=$20 ' // \  (we are using this for Case 34 " above)
    Case 93
    	FC(0)=$00:FC(1)=$41:FC(2)=$41:FC(3)=$7F:FC(4)=$00 ' // ]
    Case 94
    	FC(0)=$04:FC(1)=$02:FC(2)=$01:FC(3)=$02:FC(4)=$04 ' // ^
    Case 95
    	FC(0)=$40:FC(1)=$40:FC(2)=$40:FC(3)=$40:FC(4)=$40 ' // _
    Case 96
'    	FC(0)=$00:FC(1)=$01:FC(2)=$02:FC(3)=$04:FC(4)=$00 ' // `
        FC(0)=$02:FC(1)=$04:FC(2)=$08:FC(3)=$10:FC(4)=$20 ' // \ (shown as ` in Lookdown table)
    Case 97
    	FC(0)=$20:FC(1)=$54:FC(2)=$54:FC(3)=$54:FC(4)=$78 ' // a
    Case 98
    	FC(0)=$7F:FC(1)=$48:FC(2)=$44:FC(3)=$44:FC(4)=$38 ' // b
    Case 99
    	FC(0)=$38:FC(1)=$44:FC(2)=$44:FC(3)=$44:FC(4)=$20 ' // c
    Case 100
    	FC(0)=$38:FC(1)=$44:FC(2)=$44:FC(3)=$48:FC(4)=$7F ' // d
    Case 101
    	FC(0)=$38:FC(1)=$54:FC(2)=$54:FC(3)=$54:FC(4)=$18 ' // e
    Case 102
    	FC(0)=$08:FC(1)=$7E:FC(2)=$09:FC(3)=$01:FC(4)=$02 ' // f
    Case 103
    	FC(0)=$0C:FC(1)=$52:FC(2)=$52:FC(3)=$52:FC(4)=$3E ' // g
    Case 104
    	FC(0)=$7F:FC(1)=$08:FC(2)=$04:FC(3)=$04:FC(4)=$78 ' // h
    Case 105
    	FC(0)=$00:FC(1)=$44:FC(2)=$7D:FC(3)=$40:FC(4)=$00 ' // i
    Case 106
    	FC(0)=$20:FC(1)=$40:FC(2)=$44:FC(3)=$3D:FC(4)=$00 ' // j
    Case 107
    	FC(0)=$7F:FC(1)=$10:FC(2)=$28:FC(3)=$44:FC(4)=$00 ' // k
    Case 108
    	FC(0)=$00:FC(1)=$41:FC(2)=$7F:FC(3)=$40:FC(4)=$00 ' // l
    Case 109
    	FC(0)=$7C:FC(1)=$04:FC(2)=$18:FC(3)=$04:FC(4)=$78 ' // m
    Case 110
    	FC(0)=$7C:FC(1)=$08:FC(2)=$04:FC(3)=$04:FC(4)=$78 ' // n
    Case 111
    	FC(0)=$38:FC(1)=$44:FC(2)=$44:FC(3)=$44:FC(4)=$38 ' // o
    Case 112
    	FC(0)=$7C:FC(1)=$14:FC(2)=$14:FC(3)=$14:FC(4)=$08 ' // p
    Case 113
    	FC(0)=$08:FC(1)=$14:FC(2)=$14:FC(3)=$18:FC(4)=$7C ' // q
    Case 114
    	FC(0)=$7C:FC(1)=$08:FC(2)=$04:FC(3)=$04:FC(4)=$08 ' // r
    Case 115
    	FC(0)=$48:FC(1)=$54:FC(2)=$54:FC(3)=$54:FC(4)=$20 ' // s
    Case 116
    	FC(0)=$04:FC(1)=$3F:FC(2)=$44:FC(3)=$40:FC(4)=$20 ' // t
    Case 117
    	FC(0)=$3C:FC(1)=$40:FC(2)=$40:FC(3)=$20:FC(4)=$7C ' // u
    Case 118
    	FC(0)=$1C:FC(1)=$20:FC(2)=$40:FC(3)=$20:FC(4)=$1C ' // v
    Case 119
    	FC(0)=$3C:FC(1)=$40:FC(2)=$30:FC(3)=$40:FC(4)=$3C ' // w
    Case 120
    	FC(0)=$44:FC(1)=$28:FC(2)=$10:FC(3)=$28:FC(4)=$44 ' // x
    Case 121
    	FC(0)=$0C:FC(1)=$50:FC(2)=$50:FC(3)=$50:FC(4)=$3C ' // y
    Case 122
    	FC(0)=$44:FC(1)=$64:FC(2)=$54:FC(3)=$4C:FC(4)=$44 ' // z
    case 123
'        FC(0)=$00:FC(1)=$08:FC(2)=$36:FC(3)=$41:FC(4)=$00'  // {
    	FC(0)=$10:FC(1)=$24:FC(2)=$20:FC(3)=$24:FC(4)=$10 ' // Smily face (shown as { in Lookdown table)
    case 124
'        FC(0)=$00:FC(1)=$00:FC(2)=$7F:FC(3)=$00:FC(4)=$00 ' // |
    	FC(0)=$20:FC(1)=$40:FC(2)=$20:FC(3)=$10:FC(4)=$08 ' // Tick (shown as | in Lookdown table)
    case 125
'        FC(0)=$00:FC(1)=$41:FC(2)=$36:FC(3)=$08:FC(4)=$00'  // }
    	FC(0)=$20:FC(1)=$14:FC(2)=$10:FC(3)=$14:FC(4)=$20 ' // Frown face (shown as } in Lookdown table)
    case 126
        FC(0)=$10:FC(1)=$08:FC(2)=$08:FC(3)=$10:FC(4)=$08'  // ~
    end SELECT
FOR CharLine=0 to 4
GOSUB PomeriNiz
Displej[7]=FC(CharLine)
GOSUB Prikazi_Niz
PAUSE BrzinaSkrolovanja
Next CharLine
    Return
Main ispravi na ovo
Main:
Char="J"
BrzinaSkrolovanja=1000
GOSUB SendChar
Char="a"
BrzinaSkrolovanja =0
GOSUB SendChar
Char=" "
GOSUB SendChar
Char=" "
GOSUB SendChar
Char=" "
GOSUB SendChar
Char=" "
GOSUB SendChar
GOTO Main
Treba da definises promenljive sve koje fale kao bajt, FC niz bajtova 5 clanova, BrzinaSkrolovanja kao word.
Kad to sve proradi, onda ostaje jos samo ubaciti one makroe za ispis po displeju...
febo26
Post by febo26 »
Radi i to od prve je proradilo,slova idu s desna na lijevo jedino su zaljepljena jedno za drugo,negdje izmedju slova se mora ubacit razmak.idem nesto prigrist pa nastavak slijedi
FOR CharLine=0 to 4
GOSUB PomeriNiz
GOSUB Prikazi_Niz
Next CharLine
Iznad toga dodaj
GOSUB PomeriNiz
Displej[7]=0 ' Vertikalna prazna linija sa leve strane slova
GOSUB Prikazi_Niz
Sto se tice makroa za printanje fiksnog teksta
ASM
PrintStr macro  Str
    local TheString, OverStr
    goto OverStr
TheString
    data  Str, 0
OverStr
    MOVE?CW  TheString, _Addr
    L?CALL   _StringOut
    endm
ENDASM
StringOut:
    Readcode Addr, Char           ' Get a character
    if Char = 0 then StringDone   ' Look for Null char, Stop if found
    Lcd_Data = Char
    gosub SendChar               ' puttext
    Addr = Addr + 1               ' Point to next character
    goto StringOut                ' Continue with rest of the string
  StringDone:
return
Sada bi trebao tekst isprintati sa
@ PrintStr "Pedja089:)"
Ovo isto dodaj na kraj prethodnog koda, a u main ubaci samo
@ PrintStr "Pedja089:)" i pause 1000
Za tekst iz memorije ili odnekud trece u Char ubacis slovo, i pozoves SendChar
Za ispis promenljivih, probaj sam malo eksperimentisati, ali fazon je slican ovome...
EDIT:
Ovde u kodu koliko vidim moze da radi samo ispis WORD promenljive... Vise se ni ne secam tacno zasto je tako uradjeno...
febo26
Post by febo26 »
sad imam razmak izmedju slova , makro ne radi
febo26
Post by febo26 »
napise gresku:
ASM ERROR illegal character (")
probao sam i ovako s zarezom onda napise da je zarez greska
@ PrintStr ,"Pedja089:)"
Nemam pojma koju verziju PBP-a koristis, ali sa trojkom to prolazi bez problema.
Zaboravio sam napomenuti da se mora koristiti MPASM koji ide uz mplab, a ne onaj sto dolazi uz PBP ako je rec o verzijama manjim od 3.0
Drugi nacin ispisa bi bio ovako nesto:
For i=0 to 255
Char=0
LOOKUP i,["Pedja089"], Char
if char=0 then exit'Automatski detektuj kraj teksta, tako da ne moras svaki put brojati koliko tekst ima slova
GOSUB SendChar
Next i
febo26
Post by febo26 »
'*  Version : 1.0                                               *
'*  Notes   :                                                   *
include "pedja_5.pbp"
main:
pause 1000
goto main
dok ovo napisem ovako onda ne javlja gresku ali ispisuje svako drugo slovo
Ispise samo ej09) tocno tim redosljedom
to je fajl koji smo danas skemijali
idem jos potrazit gresku mozda ju nadjem
febo26
Post by febo26 »
picbasic pro 3.0.4.0
i MPSAM 5.43
Aha, izgleda makro mora stajati u nekom include file. Slabo sam radio sa njima. To nisam znao...
E sad zasto svako drugo slovo nisam siguran... A nemam ni vremena puno za kopati... Mislim da je to nesto oko READCODE naredbe, da ona cita 2 bajta, ili nesto slicno...
Mozes probati staviti promenljivu word u readcode, pa staviti da ti prikaze prvo jedan znak, pa drugi, ili nesto tako...
Mozes pogledati gore nacin sto sam dodao sa lookup komandom. Ona u sustini radi ovo sto je u makru napravljeno.
StringOut:
    Readcode Addr, wordChar           ' Get a character
    Char =wordChar.byte0
    Char =wordChar.byte1
  StringDone:
return
Probaj to...
EDIT:
Nadam se da si video u onom include sto sam okacio da Addr treba da bude word...
Addr VAR WORD
febo26
Post by febo26 »
Ono s LOOKUP radi bez greske. negdje je greska u makrou mada je ne vidim probao sam par kombinacija nije pomoglo
Za ispisivanje promenljive
For i = 4 to 0 step -1
char= 48+ Promenljiva DIG i
gosub SendChar
NEXT i
Mozes probati naci na MELAB forumu primer za USER COMMAND koje su ubacene u pbp3, ali nisu bas lepo dokumntovane. Pa sa njima napraviti da lepo upakovane komande za ispis na displej.
Po meni samo kozmetika, nista drugo...
febo26
Post by febo26 »
Za danas dosta kucanja po kompu,sutra slijedi novi izazov.Posto sada kompletni text scrollam po jednoj matrici
sada treba naci rjesenje kako taj cijeli text pomaknuti na jos dvije matrice
PomeriNiz:
For i=0 to 6
next i
    Prikazi_Niz:
    for Y =0 to 7
    ADDRESS = Y+1
    gosub MaxWrite
    next Y
    return
        MaxWrite:
        return
posto se podaci salju serijski naredba za slanje bi trebala izgledati ovako:
shiftout DAT,CLK,MSBFIRST,[0,0,0,0,ADDRESS,DATAREG] podaci poslani skroz desnom displeju
shiftout DAT,CLK,MSBFIRST,[0,0,ADDRESS,DATAREG,0,0] podaci poslani srednjem displeju
shiftout DAT,CLK,MSBFIRST,[ADDRESS,DATAREG,0,0,0,0] podaci poslani lijevom displeju
