Construction of Word Clock v1
Re: Construction of Word Clock v1
More pictures.
/Robert
/Robert
- Max7219 Under
- IMG_9439.JPG (60.9 KiB) Viewed 16138 times
- Max7219 no 4
- IMG_9437.JPG (47.9 KiB) Viewed 16138 times
- Max7219 no 4
- IMG_9436.JPG (39.51 KiB) Viewed 16138 times
- Max7219 no 4
- IMG_9435.JPG (51.65 KiB) Viewed 16138 times
robertholmberg wrote:More pictures.
/Robert
Robert huh!
That's pretty harsh! With the many cords do something urgent! I used to use tape ribbon cable. I think it's so gather all kinds of electrical noise! The crystals and 22pF can be closer to each other. The 2 amp power adapters plenty enough, mine also has a USB cell phone charger. (about 800 mA)
Haha,
Hmm, was it that bad? I will try to clean it all up if i got time tomorrow, and I guess that the most important one to make short and clean is the three signal cables sending the data from the chips to eachother?
/Robert
/Robert
robertholmberg wrote:Haha,
/Robert
Yes, the chip is wired up to do something with absolute guess. There is no ribbon? I used a ribbon cable used pc.
Szabi
Some pictures of my solution.
- P1020813.jpg (32.43 KiB) Viewed 16109 times
- P1020812.jpg (32.6 KiB) Viewed 16109 times
- P1020810.jpg (31.42 KiB) Viewed 16109 times
- P1020809.jpg (30.97 KiB) Viewed 16109 times
- P1020808.jpg (26.12 KiB) Viewed 16109 times
- P1020689.jpg (28.8 KiB) Viewed 16107 times
- P1020688.jpg (29.35 KiB) Viewed 16107 times
- P1020687.jpg (20.79 KiB) Viewed 16107 times
- P1020816.JPG (22.92 KiB) Viewed 16107 times
- P1020815.jpg (30.68 KiB) Viewed 16107 times
- P1020819.jpg (5.66 KiB) Viewed 16105 times
- P1020818.jpg (4.53 KiB) Viewed 16105 times
- P1020708.jpg (21.47 KiB) Viewed 16105 times
- P1020693.jpg (23.18 KiB) Viewed 16105 times
- P1020690.jpg (31.03 KiB) Viewed 16105 times
Hi,
I havent had time to test it properly and will not until next week, i did the worst corner and replaced it with such a cable which i have plenty of, and i think it might have been the problem.
Thanks for the input. And will be back with the result.
/Robert
/Robert
Hello
How do I add additional characters to the file font_7x5.h
for example, the following
0x04, 0x2A, 0x6A, 0xAA, 0x10,
but this character is not displayed
You should replace some character that you are not using with that bitmap (your new 5 bytes). That's what I did with character for temperature degree symbol. Look for it in font_7x5.h file and do the same!
Witam
Co bym musiał zmienic w programie, żeby dodać jeszcze jeden MAX (64 Diod)
Dodam, że nie znam sie na programowaniu
Hello
What would I have to change in the teeth add one MAX (64 Diodes)
I would add that it does not know much about programming
Hello
- ZEGAR.jpg (106.1 KiB) Viewed 15757 times
Hello,
It can be done, but you will need to find someone to help you with the code. I really don't have enough time right now, sorry.
Best regards,
Trax
Best regards,
Trax
Hello
I've added yet another layout MAX7219
in the file " lang " Now I
and in " wc.c " changed to this piece of code :
And something is wrong because it shows me only one half
Where can be a problem
sorry for my English
Translated by Google Translate
// MAX 2 // MAX 3
0b00000000, 0b00000000, // not on display
// MAX 1 // MAX 4
// MAX 5
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
// fetch the appropriate arrays from PGM space into RAM
char hour_arr[40];
memcpy_P(hour_arr, (PGM_P)pgm_read_word( &MAX_h[time_h-1] ), 40);
char minute_arr[40];
memcpy_P(minute_arr, (PGM_P)pgm_read_word( &MAX_m[time_m] ), 40);
// turn ON current hour's LEDs for all MAXs that might have an ON LED for this hour
// we will turn ON current minute's LEDs also here
// we do that 8 times for each MAX, for each "column" of data, even though it is actually row data because that's how I soldered the LEDs :(
for(uint8_t i=0; i<8; i++)
// MAX 1
display_matrix[0][i] |= hour_arr[16+(i*2)] | minute_arr[16+(i*2)]; // turn ON hours & minutes that need to be ON for this MAX
// MAX 2
display_matrix[1][i] |= hour_arr[i*2] | minute_arr[i*2]; // turn ON hours & minutes that need to be ON for this MAX
// MAX 3
display_matrix[2][i] |= hour_arr[(i*2)+1] | minute_arr[(i*2)+1]; // turn ON hours & minutes that need to be ON for this MAX
// MAX 4
display_matrix[3][i] |= hour_arr[17+(i*2)] | minute_arr[17+(i*2)]; // turn ON hours & minutes that need to be ON for this MAX
// MAX 5
display_matrix[4][i] |= hour_arr[24+(i*2)] | minute_arr[24+(i*2)]; // turn ON hours & minutes that need to be ON for this MAX
Hello
This display ok
lang file I have now :
wc.c file I have now:
Now is good. But I do not know how to change that date is displayed on the 3 MAX.
(MAX 1 MAX2 MAX3)
How to find moments of time colleague and was to be able to help me with the code be incorporated
This display ok
// MAX 2 // MAX 3 // MAX 6
0b00000000, 0b00000000, 0b00000000, // not on display
0b00000000, 0b00000000 ,0b00000000, // not on display
// MAX 1 // MAX 4 // MAX 5
// MAX 1
display_matrix[0][i] |= hour_arr[24+(i*3)] | minute_arr[24+(i*3)] | sekundy_arr[24+(i*3)]; // turn ON hours & minutes that need to be ON for this MAX
// MAX 2
display_matrix[1][i] |= hour_arr[i*3] | minute_arr[i*3] | sekundy_arr[i*3]; // turn ON hours & minutes that need to be ON for this MAX
// MAX 3
display_matrix[2][i] |= hour_arr[(i*3)+1] | minute_arr[(i*3)+1] | sekundy_arr[(i*3)+1]; // turn ON hours & minutes that need to be ON for this MAX
// MAX 4
display_matrix[3][i] |= hour_arr[25+(i*3)] | minute_arr[25+(i*3)] | sekundy_arr[25+(i*3)]; // turn ON hours & minutes that need to be ON for this MAX
// MAX 5
display_matrix[4][i] |= hour_arr[26+(i*3)] | minute_arr[26+(i*3)] | sekundy_arr[26+(i*3)]; // turn ON hours & minutes that need to be ON for this MAX
// MAX 6
display_matrix[5][i] |= hour_arr[(i*3)+2] | minute_arr[(i*3)+2] | sekundy_arr[(i*3)+2]; // turn ON hours & minutes that need to be ON for this MAX
(MAX 1 MAX2 MAX3)
Hello,
I am currently very busy so I can't help you right now. Maybe there is someone else that can take a look at the code here?
Regards!
Regards!
That I can not find anyone to help with the processing of code: (
Practically just about displaying the date and progressbar on 3max, I know more or less an every where change, but l can not do that, everything else is ok
It's hard I'll keep looking maybe someone from this forum will help.
Hello
I know that my friend does not have time right now, but if you can help me with display_progressbar that was displayed on three MAX7219.
Everything else I was able to somehow change the method of trial and error, but this can not cope.
MAX2→MAX3 . MAX6
MAX1 . MAX4→MAX5
I tried this:
but it is not working as it should
// progressbar, top part of display
void display_progressbar(uint8_t value, uint8_t maximum)
uint8_t rot = ((16/ maximum) * value) +0; // how many times to rotate right
uint32_t pb = 0xffff0000; // as it rotates right, we "make more progress" :)
pb = pb >> rot; // moved to the right as much as required
// move once more because it is odd and at maximum
if( maximum==value && value%2 ) pb = pb >> 1;
// lets put this progressbar into the display_matrix
// we put byte 0 to MAX 3, and byte 1 to MAX 2, and we ignore two MSB bytes of "pb"
uint8_t pb_MAX3 = (uint8_t)pb;
uint8_t pb_MAX2 = (uint8_t)( pb >> 8 );
// skip first two rows, they are used for dots. also don't draw the bottom line...
for(uint8_t i=2; i<8-1; i++)
display_matrix[1][i] = pb_MAX2;
display_matrix[2][i] = pb_MAX3;
// send the "display matrix" to all MAXes on the bus
max72xx_send_matrix();
return;
MAX1 . MAX4→MAX5
I tried this:
uint8_t rot = ((24 / maximum) * value) +0; // how many times to rotate right
uint8_t pb_MAX6 = (uint8_t)( pb >> 16 );
display_matrix[5][i] = pb_MAX6;
return;
Hello
Does enybody can help me??
I dont know how to adjust functions responsible for the rows and columns.I tried everything and still is not right.I attached photo of my hardware connection
- 8x8..jpg (65.25 KiB) Viewed 14734 times
- 6x8..jpg (62.04 KiB) Viewed 14734 times
Hello,
Have you read the first page of this topic? There is an explanation on how to identify rows and columns. It is not *that* easy though, but it can be done in couple of minutes
Trax
Trax
