Sobni termostat sa AT89C2051
Kukinjos
Re: Sobni termostat sa AT89C2051
Post by Kukinjos »
Prole... udavi svih zemalja ujedinite se!! :lol:
'Konfiguracija
$crystal = 12000000                                           ' 12MHz
$regfile = "89C2051.DAT"                                      ' Kontroler
Config 1wire = P3.7                                           ' 1Wire port
'Postavljanje interrupta
Config Timer0 = Timer , Gate = Internal , Mode = 2            ' Konfiguracija timera
Load Timer0 , 250                                             ' Početna vrijednost timera
On Timer0 T0int                                               ' Skok na interrupt podprogram
Enable Timer0                                                 ' Dopusti interrupt timera
Start Timer0                                                  ' Pokreni timer
Enable Interrupts                                             ' Globalno dopusti interrupte
'Varijable
Dim Brojac_4ms As Byte , Brojac_100ms As Byte , Brojac_1s As Byte
Dim Vrijednost As Word , Jedinice As Byte , Desetice As Byte , Stotice As Byte
Dim Bd(9) As Byte
Dim T1 As Integer
Dim T2 As Integer
Dim Temp As Word
Dim Mux As Byte
Dim Nova_temperatura As Bit
Dim Procitaj_senzor As Bit
Dim Minus As Bit
Dim Senzor_procitan As Bit
'Početne vrednosti
Reset Procitaj_senzor
Reset Senzor_procitan
Jedinice = 191
Desetice = 191
Stotice = 191
'Glavna petlja
Do
If Nova_temperatura = 1 Then
   Reset Nova_temperatura
   Vrijednost = Temp
   If Senzor_procitan = 1 Then Gosub Pretvorba
   Gosub Prikaz
End If
Loop
End
'TIMER0 INTERRUPT
T0int:
 Incr Brojac_4ms
 If Brojac_4ms = 16 Then
    Brojac_4ms = 0
    Incr Brojac_100ms
    Set Nova_temperatura
    If Brojac_100ms = 25 Then
       Brojac_100ms = 0
       Incr Brojac_1s
       If Brojac_1s = 7 Then
          Brojac_1s = 0
          Disable Interrupts
          1wreset
          1wwrite &HCC
          1wwrite &H44
          If Err = 0 Then
             1wreset
             1wwrite &HCC
             1wwrite &HBE
             Bd(1) = 1wread(9)
             1wreset
             Bd(1) = Bd(1) And &HFE
             T1 = Makeint(bd(1) , Bd(2))
             T1 = T1 * 50
             T1 = T1 - 25
             T2 = Bd(8) - Bd(7)
             T2 = T2 * 100
             T2 = T2 / Bd(8)
             T1 = T1 + T2
             Temp = T1 / 10
          Else
             Temp = 10000                                     'Prikazuje se greška - Err
          End If
          Senzor_procitan = 1
          Enable Interrupts
       End If
    End If
 End If
Return
'PODPROGRAMI
Pretvorba:
 If Vrijednost < 1000 Then
    Jedinice = Vrijednost Mod 10
    Vrijednost = Vrijednost / 10
    Desetice = Vrijednost Mod 10
    Stotice = Vrijednost Mod 10
    If Stotice = 0 Then Stotice = 10                          'gašenje nule na stoticama
    Jedinice = Lookup(jedinice , Tabela)
    Desetice = Lookup(desetice , Tabela)
    Stotice = Lookup(stotice , Tabela)
 Else
    Stotice = 134                                             'E
    Desetice = 175                                            'r
    Jedinice = 175                                            'r
 End If
Return
Prikaz:
 Incr Mux
 If Mux = 3 Then Mux = 0
 Select Case Mux
 Case 0:
 Set P3.5                                                     ' Ugasi stotice
 P1 = Jedinice                                                ' Uzmi jedinice
 Reset P3.3                                                   ' Prikaži jedinice
 Case 1:
 Set P3.3                                                     ' Ugasi jedinice
 P1 = Desetice And &B01111111                                 ' Uzmi desetice i upali točkicu
 Reset P3.4                                                   ' Prikaži desetice
 Case 2:
 Set P3.4                                                     ' Ugasi desetice
 P1 = Stotice                                                 ' Uzmi stotice
 Reset P3.5                                                   ' Prikaži stotice
 End Select
Return
'Tabela za prikaz brojeva
Tabela:
 Data 192 , 249 , 164 , 176 , 153 , 146 , 130 , 248 , 128 , 144 , 255
'BROJ: 0     1     2     3     4     5     6     7     8     9   PRAZNO
Napravio sam i ja testni sustav po tvom nacrtu "AT89C2051 termostatV.845287.sch" :) i probao sam, tako da je to samo tvoj grijeh ako ne radi :azdaja:
mojalovaa
Post by mojalovaa »
Pa jel radi?
Kukinjos
Post by Kukinjos »
Kukinjos wrote:..... i probao sam, .....
:lol:
Kukinjos
Post by Kukinjos »
Evo koda i za termostat. Kad ga upališ ide u mjerenje i regulaciju temperature, relej se pali ako je stvarna temperatura niža od postavne, a gasi kad je dostigne. Za promjenu postavne temperature pritisneš obje tipke zajedno (plus i minus), tada se displej prebaci u mod namještanja i blinka. Vrijednost mijenjaš tipkama. Kad završiš, opet pritisneš obje tipke i displej prestane blinkat, što znači da je u modu mjerenja temperature i regulacije.
'Konfiguracija
'Varijable
Dim Bd(9) As Byte
Dim T1 As Integer
Dim T2 As Integer
Dim Temperatura As Word
Dim Mux As Byte
Dim Minus As Bit
Dim Blink As Byte
Dim Tpostavno As Word
Dim Tmax As Word
Dim Tmin As Word
Dim M As Bit
Reset M
Tpostavno = 300
Tmax = 999
Tmin = 0
Relej Alias P3.0
Tplus Alias P3.1
Tminus Alias P3.2
'Početne vrednosti
Jedinice = 191
Desetice = 191
Stotice = 191
'Glavna petlja
Do
   If M = 1 Then
      Gosub Menu
   Else
         Vrijednost = Temperatura
         Gosub Prikaz
      End If
   End If
Loop
End
'TIMER0 INTERRUPT
T0int:
   Incr Brojac_4ms
      Brojac_4ms = 0
      Incr Brojac_100ms
         Brojac_100ms = 0
         Incr Brojac_1s
         If Brojac_1s = 8 Then
            Brojac_1s = 0
            Disable Interrupts
            If Tplus = 0 And Tminus = 0 Then M = Not M
            If Temperatura > Tpostavno Then
               Reset Relej
            Else
               Set Relej
            End If
            1wreset
            1wwrite &HCC
            1wwrite &H44
            If Err = 0 Then
               1wreset
               1wwrite &HCC
               1wwrite &HBE
               Bd(1) = 1wread(9)
               T1 = T1 * 50
               T1 = T1 - 25
               T2 = Bd(8) - Bd(7)
               T2 = T2 * 100
               T2 = T2 / Bd(8)
               T1 = T1 + T2
               Temperatura = T1 / 10
            Else
               Temperatura = 10000                            'Prikazuje se greška - Err
            End If
            Senzor_procitan = 1
            Enable Interrupts
         End If
      End If
   End If
Return
'PODPROGRAMI
Pretvorba:
      Desetice = Desetice And &B01111111
   Else
      Stotice = 134                                           'E
      Desetice = 175                                          'r
      Jedinice = 175                                          'r
   End If
Return
Prikaz:
   Incr Mux
   Select Case Mux
      Case 0:
      Case 1:
         P1 = Desetice                                              ' Uzmi desetice i upali točkicu
      Case 2:
   End Select
Return
Menu:
   Debounce Tplus , 0 , Povecaj
   Debounce Tminus , 0 , Smanji
   Vrijednost = Tpostavno
   Gosub Pretvorba
   Blink = Brojac_1s And &H01
   If Blink = 1 Then
      Jedinice = 255
      Desetice = 255
      Stotice = 255
   End If
   Gosub Prikaz
Return
Povecaj:
   If Tpostavno < Tmax Then Tpostavno = Tpostavno + 1
Return
Smanji:
   If Tpostavno > Tmin Then Tpostavno = Tpostavno - 1
Return
Tabela:
Komentare mi se nije dalo pisat, ajde ti to malo sam :) .
mojalovaa
Post by mojalovaa »
O kuki , hvala , :ohno: nemogu da vjerujem da si tako brz.
Evo i ja nesto radio , napravio plocicu i ako me zeza razvijac.
Otkrio mi jedan profo sta me muci kod razvijanja foto postupkom , razvijac u granulama mora biti hermeticki zatvoren da ne moze da dodje zraka i vlage do njega , jer on inace povuce CO2 iz zraka i prestane da radi.
slike plocice.rar
(147.98 KiB) Downloaded 394 times
Kukinjos
Post by Kukinjos »
Oho i to dvostrana, svaka čast na trudu :D . Kad će realizacija?
mojalovaa
Post by mojalovaa »
Cim prije , mislim da ce naj prije za vikend a naj kasnije za kraj vikenda
Kukinjos
Post by Kukinjos »
Kod sam iskomentirao, pa ćeš se lakše snaći, inače je u pravilu isti, kao i prošli, možda neka mala kozmetika.
'Konfiguracija
Config Timer0 = Timer , Gate = Internal , Mode = 2            ' Konfiguracija timera 8 bita, interni clock 1MHz
Load Timer0 , 250                                             ' Početna PRIKAZ timera za 250 uS
'Varijable
Dim Prikaz As Word , Desni As Byte , Srednji As Byte , Lijevi As Byte
Dim Bd(9) As Byte
Dim T1 As Integer
Dim T2 As Integer
Dim Mux As Byte
Dim Slijedeca_znamenka As Bit
Dim Minus As Bit
Dim Blink As Byte
Dim Tmax As Word
Dim Tmin As Word
Dim M As Bit
Relej Alias P3.0
Tplus Alias P3.1
Tminus Alias P3.2
'Početne vrednosti
Desni = 191
Srednji = 191
Lijevi = 191
Reset M
Tpostavno = 300
Tmax = 999
Tmin = 0
'Glavna petlja
Do
   If M = 1 Then                                              ' Ako su pritisnute obje tipke
      Gosub Menu                                              ' idi na menu
   Else                                                       ' ako nisu nastavi s prikazom temperature
      If Slijedeca_znamenka = 1 Then                          ' ako je došlo vrijeme
                                                              ' za prikaz slijedeće znamenke
         Reset Slijedeca_znamenka                             ' restiraj zastavicu
         Prikaz = Temperatura                                 ' i prikaži temperaturu
         If Senzor_procitan = 1 Then Gosub Pretvorba          ' ako je završila akvizicija podataka sa senzora
                                                              ' pretvori podatak za prikaz
         Gosub Prikazi                                        ' i prikaži ga na displayu
      End If
   End If
Loop
End
'TIMER0 INTERRUPT
T0int:
 Incr Brojac_4ms
 If Brojac_4ms = 16 Then                                      ' Kad odbroji 4mS
    Brojac_4ms = 0                                            ' resetiraj ga
    Incr Brojac_100ms                                         ' i povećaj brojač od 100mS
    Set Slijedeca_znamenka                                    ' Prikaži slijedeću znamenku                                   '
    If Brojac_100ms = 25 Then                                 ' Kad odbroji 100mS
       Brojac_100ms = 0                                       ' resetiraj ga
       Incr Brojac_1s                                         ' i povećaj brojač sekundi
       If Brojac_1s = 10 Then                                 ' Kad odbroji 1 sekund
          Brojac_1s = 0                                       ' resetiraj brojač
          Disable Interrupts                                  ' Zabrani interrupte
          If Tplus = 0 And Tminus = 0 Then M = Not M          ' Ako su pritisnute obje tipke
                                                              ' uđi ili izađi iz podešavanja
          If Temperatura > Tpostavno Then                     ' Ako je temperatura veća od postavne
            Reset Relej                                       ' isključi relej
          Else                                                ' a ako je manja
            Set Relej                                         ' ukljući ga
          End If
' RUTINA ZA ČITANJE SENZORA I PRETVORBU TEMPERATURE
          1wreset                                             ' Inicijalizacija senzora
          1wwrite &HCC
          1wwrite &H44
          If Err = 0 Then                                     ' Ako se senzor javlja
             1wreset                                          ' pročitaj ga
             1wwrite &HCC
             1wwrite &HBE
             Bd(1) = 1wread(9)
             Bd(1) = Bd(1) And &HFE                           ' izračunaj temperaturu
             T1 = T1 * 50
             T1 = T1 - 25
             T2 = Bd(8) - Bd(7)
             T2 = T2 * 100
             T2 = T2 / Bd(8)
             T1 = T1 + T2
             Temperatura = T1 / 10                            ' i spremi je u varijablu
          Else                                                ' a ako se senzor ne javlja
             Temperatura = 10000                              ' postavi najveću temperaturu
                                                              ' kako bi se isključio relej i
                                                              ' prikazala greška 'Err'
          End If
          Senzor_procitan = 1                                 ' Postavi zastavicu da je senzor pročitan
          Enable Interrupts                                   ' i dopusti interrupte
       End If
    End If
 End If
Return
'PODPROGRAMI
Pretvorba:
 If Prikaz < 1000 Then                                        ' Ako je temperatura u granicama
    Desni = Prikaz Mod 10                                     ' izračunaj broj za desnu znamenku
    Prikaz = Prikaz / 10                                      '
    Srednji = Prikaz Mod 10                                   ' izračunaj broj za srednju znamenku
    Lijevi = Prikaz Mod 10                                    ' izračunaj broj za lijevu znamenku
    If Lijevi = 0 Then Lijevi = 10                            ' gašenje nule na stoticama
    Desni = Lookup(desni , Tabela)                            ' uzmi izgled broja desne znamenke
    Srednji = Lookup(srednji , Tabela)                        ' uzmi izgled broja srednje znamenke
    Srednji = Srednji And &B01111111                          ' upali decimalnu točkicu na srednjoj znamenci
    Lijevi = Lookup(lijevi , Tabela)                          ' uzmi izgled broja lijeve znamenke
 Else
    Lijevi = 134                                              ' E
    Srednji = 175                                             ' r
    Desni = 175                                               ' r
 End If
Return
Prikazi:
 Incr Mux                                                     ' Povećaj varijablu za prikaz trenutne znamenke
 If Mux = 3 Then Mux = 0                                      ' ako je zadnja, vrati na početnu - desnu
 Select Case Mux
    Case 0:
        Set P3.5                                              ' ugasi lijevu znamenku
        P1 = Desni                                            ' uzmi desnu znamenku
        Reset P3.3                                            ' prikaži je
    Case 1:
        Set P3.3                                              ' ugasi desnu znamenku
        P1 = Srednji                                          ' uzmi srednju znamenku
        Reset P3.4                                            ' prikaži je
    Case 2:
        Set P3.4                                              ' ugasi srednju znamenku
        P1 = Lijevi                                           ' uzmi lijevu znamenku
        Reset P3.5                                            ' prikaži je
 End Select
Return
Menu:
   Debounce Tplus , 0 , Povecaj                               ' Idi na 'Povećaj' ako je pritisnuta tipka +
   Debounce Tminus , 0 , Smanji                               ' idi na 'Smanji' ako je pritisnuta tipka -
   Prikaz = Tpostavno                                         ' pošalji postavnu temperaturu u varijablu za prikaz
   Gosub Pretvorba                                            ' i prikaži je
   Blink = Brojac_1s And &H01                                 ' Na neparne brojeve (svakih 100mS)
   If Blink = 1 Then                                          ' ugasi display
      Desni = 255                                             ' svi segmenti na displayu su ugašeni
      Srednji = 255                                           '
      Lijevi = 255                                            '
   End If
   Gosub Prikazi                                              ' prikaži broj na displayu
Return
Povecaj:
   If Tpostavno < Tmax Then Tpostavno = Tpostavno + 1         ' povećaj post. temp. ako nije maksimalna
Return
Smanji:
   If Tpostavno > Tmin Then Tpostavno = Tpostavno - 1         ' smanji post. temp. ako nije minimalna
Return
Tabela:
Evo za tvoju temu "BASCOM za totalne neznalice".
http://www.elektronika.ba/forum/viewtopic.php?t=14230
mojalovaa
Post by mojalovaa »
:ohno: , :lol: puno se zahvaljujem , kada sam vidio ovo :shock: , skoro sam sjeo na , na zemlju , he he hee
Kuki puno hvala , sada i mi totalne neznalice mozemo da nesto razumijemo.
mojalovaa
Post by mojalovaa »
Evo gotov termostat , cim malo poslozim dokumentaciju i slike objavljujem to ovdje .
Sasvim sam zadovoljan , opet bez Kukinjosa i BOB4 ne bi bilo nista , hvala na pomoci obadvojici.
mojalovaa
Post by mojalovaa »
Kao što sam i obećao , postavljam slike termostata , shemu i program .
Tiskanu pločicu nisam postavljao jer želim da se malo i drugi potrude da nešto rade a ne da samo čekaju kada će nešto da bude gotovo pa da onda nabrzinu nešto naprave a da ništa ne nauče , ipak je cilj svakog foruma da se nešto nauči.
Termostat ima mogućnost postavljanja dvije DS1820 sonde , jedna je na samoj pločici a druga se može spojiti na konektor.
Uređaj radi na +5V , probao sam ga i na na +4V spojiti i radi , samo kada napon padne na 3.5V onda se zablesira.
Rele još nisam stavio jer ne mogu da nadjem da radi na +5V.
Ostaje još samo izrada kućišta i stavljanje u stvarni pogon u mojoj kući.
Temperatura se štela tako da se obadve tipke drže stisnute nekoliko sek. dok brojevi ne počnu da trepere , onda se sa tipkama povećava ( gore tipka) ili smanjuje ( dolje tipka) na određenu temperaturu .
Kada se naštela temperatura koju želimo , pritisnemo obadve tipke zajedno 2 sek. i termostat prelazi režim rada.
termostat + program.rar
(48.3 KiB) Downloaded 490 times
viktor_medvedovic
Post by viktor_medvedovic »
skidam kapu !! :shock:
mojalovaa
Post by mojalovaa »
Nije to jos sve finisirano.
Nisam mogao naci relej od 5V pa cu ubaciti tiristor i optokapler , samim time drasticno ce se povecati radni vjek baterija u ovom sklopu , a jos ce mo malo da gnjavimo i Kukinjos i Bob4 da im ne bude dosadno.
Uglavnom tolerancija je 0.1 stupanj , potrosnja u radu je 5V 40 mA a kada se display prebaci u sleep mod ( odnosno na displaju se ne vidi nista ) ne moze mi instrument tako malo da pokaze koliko je potrosnja.
Kada sve zavrsim postavim slike ponovo i doradjenu shemu.
mojalovaa
Post by mojalovaa »
Evo da se samo malo pohvalim , termostat uredno radi vec nekih 6 dana , za sada bez ikakvih problema.
Montirao sam ga u nadzbuknu kutiju 100x100 mm stavio na zid u boravak , preciznost je super i krece se recimo + ili - 0.1 stupanj celzijus.
Napajam ga sa 3 x 1.5V AA betrije , a umjesto relea sam stavio OK MOC3041 i triak BTA139 , ujedno je i manja potrosnja nego da ima relej.
http://www.imagebam.com/image/c19655282772356
http://www.imagebam.com/image/b444eb282772387
Doduse mogla je ici i ljepsa kutija ali to mi je bilo naj jeftinije a i jedino sto sam nasao.
Koliko si ti siguran u tih +/-0.1 :?:
DS18B20 ima preciznost +/- 0.5.
mojalovaa
Post by mojalovaa »
Ma mislio sam na ono sto mi pokazuje na digitima , nisam ga bazdario , tako mi se krece na digitu prikazana temperatura naspram zadane , recimo ako sam zadao 24 stepena , krece se od 23.9 do 24.1 u prostoru , na ono sto prikazuje termostat , a sada koliko je 100% stvarno izmjereno ne znam , morat cu naci jedan bazdareni pa da usporedim , he heee
Ako palis na 23.9 gasis na 24.1, onda ti se to zove histerezis...
mojalovaa
Post by mojalovaa »
Nepalim i ne gasim , vec je postavito da gasi na 24 stepena , ali naravno zbog tromosti sistema ( podno grijanje) temperatura varira od -do , kako sam i napisao.
Post by bob4 »
DS nema potrebe uspoređivati s bilo čime :ohno: (moje mišljenje); za ove naše potrebe.
